| LCA - Shaft and Inner Bushing https://slantsix.org/forum/viewtopic.php?t=18016 |
| Author: | bwhitejr [ Mon Jun 12, 2006 8:41 am ] |
| Post subject: | LCA - Shaft and Inner Bushing |
I just took my lower control arm bushings out. Boy that was hard!!!!!!!!!! I have the inner bushings still stuck on the LCA shaft. Anybody know how to get them off - the easy way. I know the hard way. And is it just as hard to press the new ones in? If so, could I get them pressed in at the auto parts store? bwhitejr |
| Author: | vynn3 [ Mon Jun 12, 2006 9:22 am ] |
The easy way is to take the LCA and new bushing to your favorite machine shop and pay them $10-15 each to remove the old bushing and press in the new one. One of the best $20 I ever spent! VM |
| Author: | VDART [ Mon Jun 12, 2006 4:52 pm ] |
if you have a local surplus store see if they have a large 1 3/8 NF12 tap--- tap that puppy in & press out the outer shell-- works for me--- others with welders-- use some thick washers weld them around the edge & press them out--- good -- luck-- The local shop here wanted $100 for this procedure so I found this in my 62 FSM--- plus I have access to a shop press--- good luck |
