It is currently Sun Nov 22, 2026 3:56 am
PostPosted: Tue Jun 20, 2006 1:58 pm
Will the new lower balljoints and tie-rod end rust if I keep them natural metal? Should I paint these if I want to avoid rust on these new parts?
PostPosted: Tue Jun 20, 2006 3:10 pm
yes they will rust. yes if you are anal like me you should paint them. I use castcoat engine enamel after a couple coats of primer then I get jamming clear and put a couple heavy layers of clear on them.
The cast coat is high temp and is more durable if you cure it with heat. I have tried a variety of methods and prefer my heat gun.
________
Honda cb1000
________
ZX14 VS HAYABUSA
PostPosted: Tue Jun 20, 2006 7:41 pm
I've never had a car with new balljoints and stuff.
I'm anal, but maybe not as much as you.
