| rear end widths https://slantsix.org/forum/viewtopic.php?t=18027 |
| Author: | mbwetzel [ Mon Jun 12, 2006 2:31 pm ] |
| Post subject: | rear end widths |
I have all the parts necessary to install disc brakes on the front of my 68' Barracuda. The donor car was a 75' Duster. The problem is that the lug pattern is larger on the Duster parts. In order to run the same lug pattern on the front and rear I want to change out the entire rear end. What cars have the larger lug pattern and are the same width, or close, as the rear end on my Barracuda? |
| Author: | Joshie225 [ Mon Jun 12, 2006 4:17 pm ] |
http://www.moparts.com/Tech/Archive/axle/17.html If you have a 7 1/4 (9 bolt cover) under the car now just get the same thing from a Duster or other A body that had the same disc brakes your are using for your swap. |
| Author: | 74.swinger [ Mon Jun 12, 2006 7:47 pm ] |
| Post subject: | Re: rear end widths |
Quote: I have all the parts necessary to install disc brakes on the front of my 68' Barracuda. The donor car was a 75' Duster. The problem is that the lug pattern is larger on the Duster parts. In order to run the same lug pattern on the front and rear I want to change out the entire rear end. What cars have the larger lug pattern and are the same width, or close, as the rear end on my Barracuda?
the disc brakes are going to widen the stance on the front a little so i would use all the parts from the 75 to match________ Buy Extreme Vaporizer ________ Drug Testing Kit |
| Author: | Joshie225 [ Mon Jun 12, 2006 8:20 pm ] |
All A-body rear ends are the same width. |
| Author: | 74.swinger [ Tue Jun 13, 2006 4:23 am ] |
Quote: All A-body rear ends are the same width.
yes but the disc brakes are a little wider than the drums on front.________ Rhode island medical marijuana ________ Mini (bmw) history |
| Author: | kesteb [ Tue Jun 13, 2006 4:27 pm ] |
Yes, but all A-body rear ends are the same width. If you want the larger lug pattern, then use the rear end for a '73 - ''76 A-body with disk brakes. If you don't mind using Ford parts, then a 8" rear end from a '70s Maverick or a '70s Monarch will bolt right in. |
| Author: | Reed [ Tue Jun 13, 2006 4:37 pm ] |
Plus, the wider front track is better for handling anyway. |
