It is currently Sun Nov 22, 2026 8:13 pm
 Post subject: rear end widths
PostPosted: Mon Jun 12, 2006 2:31 pm
I have all the parts necessary to install disc brakes on the front of my 68' Barracuda. The donor car was a 75' Duster. The problem is that the lug pattern is larger on the Duster parts. In order to run the same lug pattern on the front and rear I want to change out the entire rear end. What cars have the larger lug pattern and are the same width, or close, as the rear end on my Barracuda? :?:
salty
PostPosted: Mon Jun 12, 2006 4:17 pm
http://www.moparts.com/Tech/Archive/axle/17.html
If you have a 7 1/4 (9 bolt cover) under the car now just get the same thing from a Duster or other A body that had the same disc brakes your are using for your swap.
 Post subject: Re: rear end widths
PostPosted: Mon Jun 12, 2006 7:47 pm
the disc brakes are going to widen the stance on the front a little so i would use all the parts from the 75 to match
________
Buy Extreme Vaporizer
________
Drug Testing Kit
PostPosted: Mon Jun 12, 2006 8:20 pm
All A-body rear ends are the same width.
PostPosted: Tue Jun 13, 2006 4:23 am
yes but the disc brakes are a little wider than the drums on front.
________
Rhode island medical marijuana
________
Mini (bmw) history
PostPosted: Tue Jun 13, 2006 4:27 pm
Yes, but all A-body rear ends are the same width. If you want the larger lug pattern, then use the rear end for a '73 - ''76 A-body with disk brakes.
If you don't mind using Ford parts, then a 8" rear end from a '70s Maverick or a '70s Monarch will bolt right in.
PostPosted: Tue Jun 13, 2006 4:37 pm
Plus, the wider front track is better for handling anyway.
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
