| Pulling to driver's side when braking? https://slantsix.org/forum/viewtopic.php?t=18073 |
| Author: | gmader [ Thu Jun 15, 2006 2:54 pm ] |
| Post subject: | Pulling to driver's side when braking? |
Hi all, So, what checklist should I try out to figure out a pulling condition? Facts:
Thanks, Greg |
| Author: | emsvitil [ Thu Jun 15, 2006 3:42 pm ] |
A little bit of air on one side can do this.......... Pistons sticking in the caliper. A sliding caliper can bind on the pin. you mentioned new hardlines, what about the rubber lines? |
| Author: | gmader [ Thu Jun 15, 2006 4:07 pm ] |
yeah, new flex lines as well. Bleeding them again wouldn't hurt. That is a good place to start. It doesn't pull when I accellerate, so I think the alignment is probably okay. |
| Author: | argentina-slantsixer [ Thu Jun 15, 2006 5:02 pm ] |
check if your wheel bearings aren't loose. Mine did that when passg wheel was kinda "loose" |
| Author: | gmader [ Thu Jun 15, 2006 5:48 pm ] |
I will add that to the list! |
