suggestion for cam advance?
https://slantsix.org/forum/viewtopic.php?t=18095
Page 1 of 1
Author:  Matadem [ Sat Jun 17, 2006 8:14 am ]
Post subject:  suggestion for cam advance?
ok here's my cam card i've installed the cam straight up dot to dot I am using a coxbros double timing chain set...
but performance is nowhere near expected...so I am thinking the cam is/might be retarded
now a friend is going to degree the cam for me
given the specs on the camcard
should I advance the cam if yes how much?
engine:
88 thousand off the head, mild ported, os valves, headers, edel 500 carb, 3.55 gears
Author:  AndyZ [ Sat Jun 17, 2006 8:55 am ]
Can you get us some more info about what performance you're expecting and what you have now? What was your old cam and did you change your jetting or distributor for the new cam? Does the car run out of power in the upper rpm's or does it start off like a slug and then come on strong. Advancing a cam moves the power band to lower rpm's. Retarding moves the power band up to higher rpm's. What cam is that? Exhaust valve lash cold .014" seems tight according to the spec sheet.
Author:  Dart270 [ Sat Jun 17, 2006 10:17 am ]
It is ALWAYS a good idea to degree your cam - otherwise it's a crap shoot. I have gotten lucky in the past, but it's not the norm.
Also, almost every cam maker gives you a centerline that's basically for a V8. You need to advance it 4-6 deg from that spec. I would install yours at 101-103. This will not substantially kill high end, but will increase your low end a lot on a 225.
Author:  Matadem [ Sat Jun 17, 2006 11:46 am ]
it's a schneider 264 cam... with the stock cam same engine with no headers the car was way faster with lower gear also...
by monday it should be all done so I'll post results (hopefully good ones)
:D
Author:  Dart270 [ Sat Jun 17, 2006 5:32 pm ]
Do you have a stock torque converter and around 3.00 axle ratio?? If so, that cam is on the edge. A 2800 stall converter would make a HUGE difference - like 0.5-1 sec in the 1/4...
Author:  Matadem [ Sat Jun 17, 2006 6:08 pm ]
manual 3 speed, 3.55 gears in the rear
Author:  emsvitil [ Sat Jun 17, 2006 7:02 pm ]
The stock cam has 20 degrees less duration, so at low rpm it will have a power advantage...........
Author:  Matadem [ Fri Jun 23, 2006 3:38 pm ]
Woohoo :twisted:
we degree the cam with the gears dot to dot aligned it was 10 degrees off..
we repeated the process until it was at 104
and trust me it has allot of low end...burn tires with ease....running very strong! I am more than happy
but I am still having problems with those damn leaking headers :(
Author:  AndyZ [ Fri Jun 23, 2006 4:57 pm ]
Woohoo :twisted:
10 degrees is a lot! 104 is a real nice place to be on a slant. Unfortunately, as you know "header" is synonymous with "leak".
Author:  Dart270 [ Mon Jun 26, 2006 6:02 am ]
Great job. You'll never go back to dot-to-dot!
