| decking the block https://slantsix.org/forum/viewtopic.php?t=18142 |
| Author: | argentina-slantsixer [ Tue Jun 20, 2006 6:01 am ] |
| Post subject: | decking the block |
Hey there. I'm building another slant six engine. I decided to leave mine as is and go with another one so I can do things really slow and counting on me and after I finish I do a swap. The thing is I'm going with 198 rods and newer pistons (zero offset wrist pin, floating wrist pin, higher rings pack with thinner rings) and I want to know how much can I take from the top of the block safely. I'm using a custom cast /6 block produced in argentina called the 906 wich was intended for light and heavy truck operation. The block itself is more than 30 pounds heavier than the "regular" slant 6 block and withstands greater overbores (say in the .120 to .140 ballpark) W/O pricey block testings. So my recipe is kinda the nonstroker stroker /6 from dougs article 89mm metric piston and rings 198 rods erson 270º/270º .465" lift cam mopar performance small block 340 springs with damper Mopar performance 1.7 in 1.44ex valves w/ brass valve guides, combustion chambers matched to the overvore to unshroud the valves, ported and polished on the ex side, ported on the intake side. head, mains and rods ARP studs kit that would yield a 3910 cc slant six maybe if the core's good I can push 89,5 mm and get a 3954cc or 90mm and get a 3999 (4 liters) slant 6 If I can mill enough from the block and .100 from the head, I can use domed pistons and close to zero deck height to create some quench in the combustion chamber... if I can't take enough I'd have to go with flat top pistons... |
| Author: | Doctor Dodge [ Tue Jun 20, 2006 6:16 am ] |
| Post subject: | Re: decking the block |
Quote: I'm using a custom cast /6 block produced in argentina called the 906 wich was intended for light and heavy truck operation. The block itself is more than 30 pounds heavier than the "regular" slant 6 block and withstands greater overbores (say in the .120 to .140 ballpark) W/O pricey block testings.
I wish I could get my hands on one of these blocks, it sounds interesting.Quote:
So my recipe is kinda the nonstroker stroker /6 from doug's article
Don't forget the oversize valve head with some porting work, this "big inch" engine will need it.89mm metric piston and rings 198 rods erson 270º/270º .465" lift cam mopar performance small block 340 springs with damper head, mains and rods ARP studs kit that would yield a 3910 cc slant six maybe if the core's good I can push 89,5 mm and get a 3954cc or 90mm and get a 3999 (4 liters) slant 6 Quote:
Do your compression ratio calculations, the long stroke SL6 is hard to get to zero deck and still have a reasonable compression ratio. (under 12 to 1)I would try not to cut the block more then .125 and even less off the head if possible. Thick decks hold the head gasket better. DD[/quote] |
| Author: | Dart270 [ Tue Jun 20, 2006 7:19 am ] |
I would say 0.100-0.150 would be fine to cut off the block. With that big of a bore, you might want to go with bigger valves still - like 1.76/1.50. That's what Mike Jeffrey did on my head that is optimized for 0.100 over block. Lou |
| Author: | argentina-slantsixer [ Tue Jun 20, 2006 11:30 am ] |
Quote: I wish I could get my hands on one of these blocks, it sounds interesting.
I have 3 of them. Wanna get a shipping quote? I assume is going to be pricey Quote: Don't forget the oversize valve head with some porting work, this "big inch" engine will need it.
yeah, I wrote that but after the valves thing, my bad.Quote: Do your compression ratio calculations, the long stroke SL6 is hard to get to zero deck and still have a reasonable compression ratio. (under 12 to 1)
"heavy" slants have about 4mm to 5mm or even more negative deck height. I assume it's ALL reinforced... that's why I asked. Maybe I can take more than .125 if that's correct. What's the worse thing that can happen? hitting the water passages? Quote: I would try not to cut the block more then .125 and even less off the head if possible. Thick decks hold the head gasket better.
OK, I'll have to check after I get pistons (or after measure carefully and get specs for a set of custom pistons) how much can I take off the block and how much can I take from the upper half of the piston. My idea was to go as far as I can taking space from the wrist pin to the piston head to reduce side stressDD Quote: With that big of a bore, you might want to go with bigger valves still - like 1.76/1.50. That's what Mike Jeffrey did on my head that is optimized for 0.100 over block
Darn it! I already got them valves! |
| Author: | SlantSixDan [ Tue Jun 20, 2006 1:06 pm ] |
Quote: I understand that you also had heavier blocks (maybe I got it wrong??)
You might be thinking of one of the articles that have been floating around for a few decades claiming there was a 240 CID slant-6 used in trucks. Which isn't true, there wasn't (sad to say). We didn't get any of these what you are talking about (extra-heavy/extra-meaty blocks). |
| Author: | AndyZ [ Tue Jun 20, 2006 2:55 pm ] |
Wasn't there a heavy duty truck slant produced in the 60's used in Power Wagons? They were painted yellow, had shot peened rods and from what I remember, the block was beefier? Some other upgraded components were installed as well. Or am I wrong? |
| Author: | SlantSixDan [ Tue Jun 20, 2006 3:38 pm ] |
Quote: Wasn't there a heavy duty truck slant produced in the 60's used in Power Wagons? They were painted yellow, had shot peened rods and from what I remember, the block was beefier? Some other upgraded components were installed as well. Or am I wrong?
You're not wrong about there being heavy-duty slant-6s produced in the '60s and '70s. There were two levels of "heavy duty", depending on the application and severity of intended service. The changes were to internal components (e.g. chrome rings, bimetal bearings, double-roller timing chain, shot-peened crankshaft, HV oil pump, polyacrylic valve stem seals, upgraded valve material, positive exhaust valve rotators) and to the calibration of carburetion and ignition timing curves. The blocks were not different or heavier than the passenger car blocks of the same years, but the HD blocks were "select" items (more rigourously tested on the assembly line).
| Author: | RossKinder [ Tue Jun 20, 2006 4:28 pm ] |
Quote: You might be thinking of one of the articles that have been floating around for a few decades claiming there was a 240 CID slant-6 used in trucks. Which isn't true,
ACK! Does that mean those 150 and 250 Slant 6's on eBay every now and then aren't correctly described?????? Thanks |
| Author: | argentina-slantsixer [ Tue Jun 20, 2006 7:15 pm ] |
Quote: Quote: I understand that you also had heavier blocks (maybe I got it wrong??)
You might be thinking of one of the articles that have been floating around for a few decades claiming there was a 240 CID slant-6 used in trucks. Which isn't true, there wasn't (sad to say). We didn't get any of these what you are talking about (extra-heavy/extra-meaty blocks). In exchange, the ACTC (Asociación de corredores de Turismo Carretera or turismo road racing asociation, turismo is taken from the italian word application to describe good road cars) did cast some very few cyl heads with heart shaped combustion chambers and very well enlarged ports and valve seats, 1.7 & 1.44 or even larger. I'm after one of these... |
| Author: | Doctor Dodge [ Tue Jun 20, 2006 10:18 pm ] |
Quote: ...one article from DD said to take in account the weight of the block if you're going to build a hi-output application and choose the heavier. Maybe that's what combined with the fact that we had those beefier blocks mislead me to believe you had those beefier blocks too.
It is true that a 68 thru 76 block weighs a few lbs more then some of the other years but the cylinder walls and deck thickness is appx. the same through all the years. To find a "better" SL6 block is more of a inspection & selection process instead of finding a certain year and casting number. DD |
| Author: | argentina-slantsixer [ Wed Jun 21, 2006 8:15 am ] |
Quote: It is true that a 68 thru 76 block weighs a few lbs more then some of the other years but the cylinder walls and deck thickness is appx. the same through all the years.
Gee, for us is just as easy as finding a 906 ending casting #'s block. guess I got the good end at SOMETHING! To find a "better" SL6 block is more of a inspection & selection process instead of finding a certain year and casting number. DD |
| Author: | Doctor Dodge [ Wed Jun 21, 2006 11:11 am ] |
Gee, for us is just as easy as finding a 906 ending casting #'s block. Guess I got the good end at SOMETHING!
Please apply some stamps and mail me one of those special thick wall SL6 blocks so I can get a look at it. Don't spend more then $5.00 on postage! DD |
| Author: | SlantSixDan [ Wed Jun 21, 2006 11:35 am ] |
