| Romac Harmonic Balancers and Rollmaster Timing Chains https://slantsix.org/forum/viewtopic.php?t=18147 |
| Author: | Greg Ondayko [ Tue Jun 20, 2006 11:03 am ] |
| Post subject: | Romac Harmonic Balancers and Rollmaster Timing Chains |
These are High Quality Aussie Products They Offer SFI approved Harmonic Balancers With Pulley Groove and High Quality Double Roller Timing sets too - I believe you can even get the cam gear with an adjustable degree feature in it. Very Cool Quality stuff from the slanters down under! http://www.romac.com.au/ http://www.romac.com.au/pdf/2005%20C&B% ... 20List.pdf Greg |
| Author: | SlantSixDan [ Tue Jun 20, 2006 1:23 pm ] |
Looks like nice quality stuff, fer sher. I don't see the vernier-adjustable cam sprocket for the slant-6, only for small LA and big B/RB V8s. I can't recall if the slant uses the same cam sprocket as the B/RB, or if it uses the same crank sprocket. It's one or the other. I've got timing sprockets and chains on the brain today. This morning, I was digging through FPCs to try and figure out if it was '70, '71 or '72 when they first used the aluminum cam sprocket with nylon teeth. '72: 2806 945. '70: 2806 945. H'mmm. Turns out that P/N was introduced in the '67 FPC ("Part not listed in any previous parts catalogue"). In '66, we see the 1947 XXX number which dates back to '60. OK, so I definitely need to do the "hand turn the engine back and forth" test on my '71 with 142k miles to see how far I can turn it before the distributor rotor moves. IIRC those nylon-over-aluminum sprockets have a reputation for getting chewed up and letting the chain go slack. |
| Author: | Dart270 [ Tue Jun 20, 2006 1:42 pm ] |
Cam sprocket is different on BBM and /6, crank and chain same. Cameron Tilley has just had some adjustable billet cam gears made for the Romac chain. I think Tom Drake is handling US sales... Lou |
| Author: | SlantSixDan [ Tue Jun 20, 2006 1:52 pm ] |
Interesting. Thanks. |
| Author: | argentina-slantsixer [ Tue Jun 20, 2006 7:31 pm ] |
Yeah, B/RB shares oil slinger, crank sprocket, chain an rear main seal with the slant 6. Just got me a set of fel-pro rear main seal rubber replacement. Got tired of dealing with the f++cking piece of rope! |
| Author: | Greg Ondayko [ Tue Jun 27, 2006 7:13 pm ] |
| Post subject: | I got one |
I just got A romac Damper For the slant. Nice Piece. It has Timing marks built in, with a Belt pulley in the stock location for you street acc. folks. It is Rebuildable and I got it for a nice price on Ebay. Just search for Romac / THe vendor was hd_mad_dog He aparrently has been importing romac Equipment. Greg |
| Author: | james longhurst [ Tue Jun 27, 2006 7:57 pm ] |
yep, got one for my sb car. very nice compared to the cheap "fluidamper" i had. very lightweight. swap to that damper and alum flywheel and modified t-q really made a difference. much quicker revs. i bet a slant would like the same. -james |
| Author: | featherduster76 [ Fri Jun 30, 2006 4:00 pm ] |
james longhurst wrote:yep, got one for my sb car. very nice compared to the cheap "fluidamper" i had. very lightweight. swap to that damper and alum flywheel and modified t-q really made a difference. much quicker revs. i bet a slant would like the same. Hoping to find out oneday James...I have the rollmaster and the romac waiting for the '66 barracuda drag car. These look like very nice pieces... |
| Author: | Greg Ondayko [ Mon Dec 24, 2007 11:57 am ] |
| Post subject: | Timing Marks |
The Romac Balancer uses the Timing marks from a 66-and older Front timing cover - I didnt have one on those timing covers layin around so I just Got out the old trusty paint Marker and Painted on TDC - I guess you could cut off the timing tab and reweld it to the passenger side of the cover too. FYI - Link Below: http://www.slantsix.org/forum/viewtopic ... 7&start=30 Greg |
| Author: | 68barracuda [ Mon Mar 30, 2009 4:07 am ] |
Nice thing about RSA slants - we never changed that bit - only updated the cylinder heads |
| Author: | 68barracuda [ Mon Mar 30, 2009 4:09 am ] |
Nice thing about RSA slants/Valiants - we never changed much - the timing cover stayed pre 66 style till 81, always had forged cranks, updated cylinder heads in 68 - the suspension parts stayed the same from beginning to end |
| Author: | volaredon [ Mon Mar 30, 2009 6:41 am ] |
I've dealt with that Ebay seller before had good service. |
