| To paint LBJ and Tie Rod Ends (or not to) https://slantsix.org/forum/viewtopic.php?t=18150 |
| Author: | sixsignet [ Tue Jun 20, 2006 1:58 pm ] |
| Post subject: | To paint LBJ and Tie Rod Ends (or not to) |
Will the new lower balljoints and tie-rod end rust if I keep them natural metal? Should I paint these if I want to avoid rust on these new parts? |
| Author: | 74.swinger [ Tue Jun 20, 2006 3:10 pm ] |
yes they will rust. yes if you are anal like me you should paint them. I use castcoat engine enamel after a couple coats of primer then I get jamming clear and put a couple heavy layers of clear on them. The cast coat is high temp and is more durable if you cure it with heat. I have tried a variety of methods and prefer my heat gun. ________ Honda cb1000 ________ ZX14 VS HAYABUSA |
| Author: | sixsignet [ Tue Jun 20, 2006 7:41 pm ] |
I've never had a car with new balljoints and stuff. I'm anal, but maybe not as much as you. |
