| oil level https://slantsix.org/forum/viewtopic.php?t=18157 |
| Author: | Slant n' Rant [ Tue Jun 20, 2006 7:52 pm ] |
| Post subject: | oil level |
I swear I checked my oil the one day and it read half over add then only one week later I began smelling burnt oil PS after a few hundred miles, my oil is still clear, Ive never had oil stay clean that long before it must be that wix filter- valve chatter gone too at start up which I got with the fram |
| Author: | KBB_of_TMC [ Wed Jun 21, 2006 10:30 am ] |
| Post subject: | oil leak |
I've heard of Ford L6's eating lots of oil on the hwy, but none around town, but never a /6. It guess it could happen if something gets hot and leaks, but closes up when cold. Look at the plugs for one that sees oil sometimes. If it shows up again, you might try a thicker oil or a thickening agent like MotorMedic, STP, or Lucas. I've had good luck using Motor Honey to greatly reduce on oil consumption. It never seemed to have any adverse effect that I could see. [I have read an article that cautioned that Lucas etc. could cause foaming and hurt lubrication, but I've never seen any evidence for it myself. It did seem to me that the tests in the article didn't mimic a Mopar oil system very well, as there should be no air present in the pump.] |
| Author: | Doctor Dodge [ Wed Jun 21, 2006 11:05 am ] |
A sticking or clogged PCV valve will do that. Be sure to check the hole into the carb and intake, sometimes these get plugged or "coked-up" and reduce the high speed crankcase venting. A mis-installed or incorrect carb to intake gasket will also cause this problem. DD |
| Author: | Slant n' Rant [ Thu Jun 22, 2006 12:43 pm ] |
All misc. parts are new including pcv and hose. I noticed initially that #3 cylinder fouled when experimenting with synthetic 5w30 ( howww looow can you gooo) but that proved to thin. Due to financial constraint I reluctedly went back to dino 10w30. With the amount of gunk that used to be in this engine when i bought it, and now its cleaned, I guess things will take awhile to seal properly again if at all. I used to use Lucas gas treatment religiously in my suburban for it had an injector, the slant, maybe not so but have used STP fuel for it. |
| Author: | Matt Cramer [ Thu Jun 22, 2006 12:53 pm ] |
| Post subject: | Re: oil leak |
Quote: I have read an article that cautioned that Lucas etc. could cause foaming and hurt lubrication, but I've never seen any evidence for it myself. It did seem to me that the tests in the article didn't mimic a Mopar oil system very well, as there should be no air present in the pump.
The test that you're talking about was probably the one on Bob is the Oil Guy. He was trying to evaluate the usefulness of that gear climbing behavior that they show off on their displays, which is really only useful in things like manual transmissions or differentials where there is no oil pump. The frothing is less likely to happen inside an engine - then again, the gear climbing behavior isn't very useful there, either.
| Author: | emsvitil [ Thu Jun 22, 2006 1:37 pm ] |
Quote: Quote: I have read an article that cautioned that Lucas etc. could cause foaming and hurt lubrication, but I've never seen any evidence for it myself. It did seem to me that the tests in the article didn't mimic a Mopar oil system very well, as there should be no air present in the pump.
The test that you're talking about was probably the one on Bob is the Oil Guy. He was trying to evaluate the usefulness of that gear climbing behavior that they show off on their displays, which is really only useful in things like manual transmissions or differentials where there is no oil pump. The frothing is less likely to happen inside an engine - then again, the gear climbing behavior isn't very useful there, either.Have you noticed that it is much harder to turn the 'better' oil than the 'plain' oil at the same speed on the display model............ |
| Author: | 75duster [ Tue Jun 27, 2006 6:29 pm ] |
has anyone heard of the new "super light weight" (0w 30) oils not having enough added zinc in them to make brand new cams fail? there was a pretty interesting article in Hot Rod about it |
| Author: | CStryker [ Tue Jun 27, 2006 8:30 pm ] |
Define "brand new" cams... during the break-in period I wouldn't dream of using anything lighter than at least a 10-30 and I'd stick with conventional oil as well. (As far as I know all 0-30's are synthetic.) |
