| Freakin' power steering!!!! https://slantsix.org/forum/viewtopic.php?t=18160 |
| Author: | StradSixer [ Tue Jun 20, 2006 10:01 pm ] |
| Post subject: | Freakin' power steering!!!! |
So, I just replaced the power steering pump (myself) and the gearbox (mechanic did that) like, 2 months or so ago. It worked great, up until a week ago, and now it's leaking like mad. It seems to be coming out from the pump, and I think if I tighten where it's leaking it will stop... but still, that's totally annoying. Any ideas as to what could cause it to loosten up so quickly? The ONLY thing I don't like about my Dart is the problems I thought I was DONE with that involved the power steering. Grr. -KC 1970 Dart Custom (4 Dr) w/ 225 |
| Author: | 74.swinger [ Wed Jun 21, 2006 4:29 am ] |
Where exactly is it leaking from? Many times they leak around the shaft. ________ Digital vaporizer ________ DC MEDICAL MARIJUANA DISPENSARY |
| Author: | KBB_of_TMC [ Wed Jun 21, 2006 10:38 am ] |
| Post subject: | Ps |
If you have a Saginaw pump, this may be relevant. When I rebuilt mine, it was quite easy (simplier than rebuilding a carb), except the rebuild kit came with 2 sets of O-rings that seal the body to the reservoir and were slightly different thicknesses. Eventually I found that on the back of the instructions (where I'd overlooked it) was a note that there had been a subtle design change in the pumps. It is easy to use the wrong O-rings; they don't look all that different, and I suppose using the wrong ones could make for a nasty leak. |
| Author: | StradSixer [ Wed Jun 21, 2006 2:12 pm ] |
Well, I took it to a mechanic and he says the pump is bad. I JUST replaced it about a month ago, so I'm going to exchange it for a new one. HOpefully that will fix the problem. grr. -KC |
| Author: | SlantSixDan [ Wed Jun 21, 2006 2:19 pm ] |
Quote: Well, I took it to a mechanic and he says the pump is bad. I JUST replaced it about a month ago
"Remanufactured" from the parts store...?
| Author: | 74.swinger [ Wed Jun 21, 2006 3:19 pm ] |
A1 Cardone strikes again probably. ________ No2 vaporizer ________ ARIZONA MEDICAL MARIJUANA DISPENSARIES |
| Author: | StradSixer [ Wed Jun 21, 2006 4:17 pm ] |
Yep, I'm pretty sure it's a remanufactured from A1 cardone. Hooray. |
| Author: | Orange72 [ Sat Jun 24, 2006 12:33 am ] |
Unless you really like power steering, I would say just go to manual. Much less of a headache, and better road feel. |
| Author: | Lars [ Sat Jun 24, 2006 4:03 pm ] |
I fixed my PS leaks by switching to manual steering. Better road feel, less weight, one less belt to break, more room in the engine compartment... |
