| Imaginary post? https://slantsix.org/forum/viewtopic.php?t=18171 |
| Author: | RossKinder [ Wed Jun 21, 2006 7:15 pm ] |
| Post subject: | Imaginary post? |
I could have sworn that just a couple nights ago I saw a post saying a Maverick hub would fit right onto a Valiant spindle, furnishing a 4.5" bolt circle. But a search on Maverick netted me nothing. Was it here or did I see that some place else? (I know about the posts regarding Maverick rear ends. That isn't what I'm talking about.) |
| Author: | Jeb [ Wed Jun 21, 2006 7:19 pm ] |
The search engine is on the fritz. |
| Author: | SlantSixDan [ Wed Jun 21, 2006 8:29 pm ] |
The search engine isn't as broken as all that. It won't handle phrase searches, but it'll do word searches just fine, and there was never any such a post as RossKinder mentions on this site. RK, you either hallucinated it, or saw it elsewhere. In either event, it's almost certainly not true. |
| Author: | dakight [ Wed Jun 21, 2006 8:50 pm ] |
There was a post that mentioned swapping a Maverick rear end into an A-body to get large bolt pattern at the rear. Perhaps that is the source of confusion. |
| Author: | VDART [ Thu Jun 22, 2006 4:35 am ] |
maverick hub-- I also have read the maverick hub story-- I think it was on all-par or the Houston club web site---- Have not tried it or looked into it further--- |
| Author: | RossKinder [ Thu Jun 22, 2006 5:59 am ] |
Quote: There was a post that mentioned swapping a Maverick rear end into an A-body to get large bolt pattern at the rear. Perhaps that is the source of confusion.
As a matter of fact there are quite a few such posts over time, which is one reason I excluded them in my first query on this.Thanks |
| Author: | Reed [ Thu Jun 22, 2006 7:11 am ] |
I don't know about Maverick hubs, but I have been told that some years of AMC hubs will fit and give the 4.5 bolt circle. |
| Author: | bbbbbb9 [ Thu Jun 22, 2006 7:38 am ] |
Just curious. Why would one want to do this? |
| Author: | Reed [ Thu Jun 22, 2006 8:55 am ] |
To avoid having to swap to disc brakes to have the 4.5 bolt circle all the way around. On a daily driver one barrel slant six ten inch drums all around is plenty to stop the car. If someone upgrades to a later rear axle with the large bolt pattern it is much simpler just to swap the front drums to get the large bolt pattern up front. |
| Author: | bbbbbb9 [ Thu Jun 22, 2006 9:19 am ] |
So we're talking spindle out or just backing plate and drum |
| Author: | RossKinder [ Thu Jun 22, 2006 9:29 am ] |
Quote: Just curious. Why would one want to do this?
My understanding of whatever I read where ever I read it was that the Maverick hubs/drums had a 4.5 inch bolt pattern. That should mix well and easily with a Maverick rear end (if it were real-world).Thanks |
| Author: | Reed [ Thu Jun 22, 2006 9:45 am ] |
My recollection of the AMC hub swap was that it is simply replacing the hub and maybe the shoes (different width?). No backing plate replacement. I have never worked on an AMC car so I can't say for sure. |
