| Valiant Signet 1966 https://slantsix.org/forum/viewtopic.php?t=18214 |
| Author: | skraecken [ Sat Jun 24, 2006 2:07 pm ] |
| Post subject: | Valiant Signet 1966 |
Tested my G-tech pro tonight. Footbraked to 1500rpm 0-60 10,67 1/4 18,04 Speed 75,2 (I do not know hove much I can trust a "G-tech") Shaved head 0,100 Polished and ported (with a Dremel). Bore 0,30 |
| Author: | skraecken [ Sun Jul 02, 2006 2:48 am ] |
| Post subject: | G-tech pro again |
Put on 2 1/2" exhaust. Timing 9 btdc Starting at 1000rpm 0-60mph 9,95 1/4 mile 17,65 Speed 78,4mph |
| Author: | skraecken [ Wed Jul 18, 2007 1:46 pm ] |
New cam, pertronix and 1 passenger (my daughter) Timing 15 btdc Manual shifting at 4000rpm Starting at 1500rpm 1/4 mile 17,59 Speed 79,1 mph |
| Author: | sandy in BC [ Wed Jul 18, 2007 8:10 pm ] |
About now a set of 3.23 gears would help. Those are solid #s for a Super 6 |
| Author: | skraecken [ Wed Jul 18, 2007 11:23 pm ] |
Quote: About now a set of 3.23 gears would help.
Your right.I have one at home, my son has promised to "scrape" it and paint it, but it does not go so fast, hope I can get it on before the winter. |
| Author: | skraecken [ Sun Jul 13, 2008 10:13 am ] |
0-60 9.12 1/4 17.17 Speed 82.5 |
| Author: | skraecken [ Sun Jul 13, 2008 1:54 pm ] |
Manual shifting 0-60 8.20 1/4 16.54 Speed 85.1 |
| Author: | slantzilla [ Sun Jul 13, 2008 2:00 pm ] |
Cool! |
| Author: | skraecken [ Sun Jul 13, 2008 2:13 pm ] |
Thank you |
| Author: | sandy in BC [ Sun Jul 13, 2008 4:57 pm ] |
Nice progression! |
| Author: | skraecken [ Wed Jul 16, 2008 1:06 pm ] |
Manual shifting 0-60 7.69 1/4 16.10 Speed 88.2 Still the secondaries will not open, (even with a short yellow spring) Maybe the carb is to big? |
| Author: | Dart270 [ Wed Jul 16, 2008 1:25 pm ] |
Great progress. The front 2 barrels of that carb are well enough to run 15s in that car, so yes, it is overkill. However, since you have it on there, you may as well tune it up and use it. Vac secondaries will just not open as you say. Lou |
