It is currently Thu Nov 26, 2026 7:04 pm
 Post subject: 74 Dart...newbie Q:
PostPosted: Mon Jun 26, 2006 9:09 am
Ok, I'm not very educated here/new at all of this so it may be a "silly" question. I recently replaced my starter, the old one wouldn't turn over all the time and noticed it was cracked around the + connnection. I installed the new one fine, but now it makes a loud clicking sound when I go to start it. But it dosen't do that when I touch the + and - with a screwdriver. Did I do something wrong/or is something else going on???
Appreciate any help here!
thx.
PostPosted: Mon Jun 26, 2006 9:13 am
Selinoid or low battery make that sound
PostPosted: Mon Jun 26, 2006 9:26 am
Check your battery cables (both of them) carefully. In addition to visible signs of degradation (extreme corrosion, broken-off ends) they can break internally, preventing enough current passing to run the starter.
It is probably not your solenoid, but if this is a "remanufactured" starter from the parts store, an off-the-shelf failure is entirely possible.
PostPosted: Mon Jun 26, 2006 9:48 am
ahh very cool. Thank you. The + cable is new, but I noticed yesterday the - cable is old and goes through a splitter of some sort...maybe there is where the problem is? Should I check it via a continuity test with my multimeter?
PostPosted: Mon Jun 26, 2006 10:19 am
Spelling Police!! Sorry at work and didn't spell check
Users browsing this forum: GTS225 and 26 guests
