| Torx size for checking rear fluid https://slantsix.org/forum/viewtopic.php?t=18234 |
| Author: | Guest [ Mon Jun 26, 2006 6:01 am ] |
| Post subject: | Torx size for checking rear fluid |
Does anyone know the correct torx wrench size for the fluid fill/level check hole in the 7 1/4" rear? I didn't know they had torx in '63. |
| Author: | Dart270 [ Mon Jun 26, 2006 6:09 am ] |
Should just be a 1/2" socket drive. Lou |
| Author: | SlantSixDan [ Mon Jun 26, 2006 7:38 am ] |
Yeah, that's not Torx, it's just a "double square" 8-point socket-head plug. I use a 3" length of ½" bar stock from the hardware store, clamped in a Vise-Grips. |
| Author: | Guest [ Mon Jun 26, 2006 9:15 am ] |
OK. Good deal. Thanks much. Then that probably would be the same thing for the oil galley plug at the back of the engine block (wish I would've asked sooner). |
| Author: | Charrlie_S [ Mon Jun 26, 2006 1:49 pm ] |
Oil galley plugs are 5/16 allen head or square |
