| 7 1/4" Axle Seal Installation https://slantsix.org/forum/viewtopic.php?t=18279 |
| Author: | slantvaliant [ Wed Jun 28, 2006 12:44 pm ] |
| Post subject: | 7 1/4" Axle Seal Installation |
When I pulled the axles from a '64 7 1/4" rear, I noticed something. The axle seals on both sides of the car were installed with the lip (concave) side out, so you could see them. ![]() (New seal pictured. The old ones got mangled a bit on the way out) The flat faces were inboard. ![]() That ain't right, is it? By the way, they did not come out easily. One had been leaking a bit. |
| Author: | slantvaliant [ Wed Jun 28, 2006 12:59 pm ] |
Oops! Meant to put this in the Transmission and Rearend section. |
| Author: | slantzilla [ Thu Jun 29, 2006 7:45 am ] |
Yep, flat side out. |
| Author: | sixsignet [ Thu Jun 29, 2006 5:46 pm ] |
| Post subject: | Is that all you have to replace if you pull it? |
I want to pull the left rear axle on my 63 to put in right-hand wheel bolts/studs. I don't detect any unusual noises from the rear axle. Can I just replace this seal, or are there other parts to renew? |
