It is currently Fri Nov 27, 2026 7:59 am
 Post subject: just a question or two
PostPosted: Fri Jun 30, 2006 8:17 am
i was wondering if there is suppose to be a spring located under the rotor button in the dizzy and im also wondering if its important that i run to the junkyard to replace the fan shrout i busted?..im seeing my temp guage go up a lil and i recently removed it cause the fan cracked it in half.
2003 Ford Escape
1993 Mustang Cobra *stock*
1991 Honda Civic boosted ls/vtec *toy*
1982 Dodge Diplomat *daily driver*
PostPosted: Fri Jun 30, 2006 10:44 am
If the fan cracked it half, you might want to check your motor mounts. Shrouds are critical with A/C and in high HP cars. If it came with a shroud, you probably should keep it.
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
