| just a question or two https://slantsix.org/forum/viewtopic.php?t=18310 |
| Author: | Slantin Forward [ Fri Jun 30, 2006 8:17 am ] |
| Post subject: | just a question or two |
i was wondering if there is suppose to be a spring located under the rotor button in the dizzy and im also wondering if its important that i run to the junkyard to replace the fan shrout i busted?..im seeing my temp guage go up a lil and i recently removed it cause the fan cracked it in half. |
| Author: | Guest [ Fri Jun 30, 2006 10:44 am ] |
If the fan cracked it half, you might want to check your motor mounts. Shrouds are critical with A/C and in high HP cars. If it came with a shroud, you probably should keep it. |
