| 7.25 gear lash... https://slantsix.org/forum/viewtopic.php?t=18322 |
| Author: | featherduster76 [ Fri Jun 30, 2006 3:07 pm ] |
| Post subject: | 7.25 gear lash... |
What is needed to setup the gear lash on my 7.25 rear??? |
| Author: | Doctor Dodge [ Fri Jun 30, 2006 6:07 pm ] |
1960 - 70 use shims to adjust the 'backlash', after 1970 there are 2 adjuster screws that you need a special tool to turn. (a C- body torsion bar works) Is this a new set of gears or are you readjusting a used set of gears? DD |
| Author: | featherduster76 [ Sat Jul 01, 2006 6:54 am ] |
This is a new set of gears placed in the rear recently. The rear is a 7.25 SG (cone type)from a '73 or 74 Dart sport. Trying to get the roar out of it.... |
| Author: | Doctor Dodge [ Mon Jul 03, 2006 10:46 am ] |
It sounds like you need to reset the pinion depth and then reset the backlash. What is the gear contact pattern telling you to do? Gear Contact Patterns http://www.motivegear.com/tech_info/R_P ... tions.html DD |
