| Won't start after storage https://slantsix.org/forum/viewtopic.php?t=18340 |
| Author: | typhoon [ Sat Jul 01, 2006 8:46 pm ] |
| Post subject: | Won't start after storage |
Hi, Have a 225 in my Australian truck. The truck has been sitting in my garage and been having various things done to it over the past year. When I stopped starting teh truuck and moving it around it was running fine. Now, it will not start. I have been through the wiring and it all seems correctly wired. The problem is that I have about 5v at the coil when cranking, obviously inadequate. I am managing to get a spark out of it, and it is hitting occasionaly ona cylinder, but won't catch. The ballast resistor, coil, plugs, cap and rotor are all new (but been sitting for a while with the rest of teh truck). Now, regarding teh ballast resistor, this is a points system with a single ballast. Is there supposed to be a source of switched 12v that bypasses the ballast when cranking, to fatten up voltage to the coil? I have around 6v coming out of the ballast on teh coil side and about 8v coming into the ballast. I should have around 12v at the other side of the ballast? Regards, Andrew. |
| Author: | Slant6Ram [ Sun Jul 02, 2006 1:51 pm ] |
| Post subject: | First of all. |
Quote: and about 8v coming into the ballast.
That's a problem. You should have a good 12v into the ballast. You'll need to trace wires until you find the short or weak connection.Quote: Is there supposed to be a source of switched 12v that bypasses the ballast when cranking,
There is on the models that I own, (see my signature below) but I don't know the specifics of your truck.
| Author: | typhoon [ Sun Jul 02, 2006 10:17 pm ] |
Thanks, kind of confirms things for me. I haven't spent a lot of time with points, I grew up with Chryslers electronic ignitions. Regards, Andrew. |
