| 66 Cuda "Charlies Angel" (Kelly) https://slantsix.org/forum/viewtopic.php?t=18346 |
| Author: | Charrlie_S [ Wed May 03, 2006 3:55 pm ] |
| Post subject: | 66 Cuda "Charlies Angel" (Kelly) |
The Cuda lives, again. Will have nitrous, but I dropped it back to 125hp. This motor has cast pistons. My headers are pretty much shot, but I can still get a little more use out of them. They are only 25 yrs old |
| Author: | Charrlie_S [ Wed Jun 21, 2006 3:37 am ] |
| Post subject: | Pics from GA Race |
Here's a few of the Cuda at the Mopar Southern Nationals in Georgia ![]() 60 foot 1.869 1/8 mile 8.431 at 80.24 1/4 mile 13.378 at 98.33 ![]()
| Author: | Charrlie_S [ Sun Jul 02, 2006 9:27 am ] |
Car weight 3250 with driver. 170 slant six, stock short block, except for a Crane cam, .434 lift and 222* dur ar .050. Head is milled for 9.5 compression.
| Author: | Reed [ Sun Jul 02, 2006 10:44 am ] |
Looking good Charlie! I'm jealous! |
| Author: | Joshie225 [ Sun Jul 02, 2006 12:04 pm ] |
Charlie, Tell us more about the engine, cylinder head in particular. Also, is the Pro on the windshield for the .400 sec Pro Tree? |
| Author: | Charrlie_S [ Sun Jul 02, 2006 12:36 pm ] |
The block is a totally stock std bore short block. Hand honed with a "dingleberry" hone, stock cast pistons, plain cast rings. Homemade full groove main bearings. New rod bearings, cam bearings, stock type timing set, std oil pump. Cam is one I have been running since the late '70's, 222 duration at .050 and .434 lift. Stock valve train. Cyl. head is totally stock except for approx .100 mill for 9.5 compression, and 340 valve springs w/dampers. Intake is a stock cast iron 1 bbl, modified for a 500 holley 2 bbl carb, and a nitrous fogger system. Clifford headers. Trans is a Push Button shifted 904, with a 3,000 converter, and a manual valve body. Rear is "A" body 8 3/4 with a 4.56 SG. Slicks are 6x26x15. With muffers, the car is street legal/drivable. The "PRO" on the windshield is just a class designation. 13.99 and quicker, no electronics (foot brake). Handicap start .500 full tree. |
