| dual intake/ dual exhaust https://slantsix.org/forum/viewtopic.php?t=18359 |
| Author: | 64'4$peed [ Sun Jul 02, 2006 6:39 pm ] |
| Post subject: | dual intake/ dual exhaust |
I was going to go the super six, dutra duals, modify your existing manifold route. Then realized that with my 64' linkage a dual 1bbl would be easier/cooler looking. would I need dual dutra duals. or does the back half of the stock manifold still work with the offy dual 1bbl. |
| Author: | HyperValiant [ Sun Jul 02, 2006 7:39 pm ] |
The back half works just fine with the Offy manifold as it was designed to be used with the stock exaust. HyperValiant |
| Author: | NewLancerMan [ Sun Jul 02, 2006 7:52 pm ] |
The dutra dual setup will just let it breathe easier. The offy setup is "easier" to setup with your throttle rod, and its pretty nice. The trick is getting two matched carbs. MJ |
