| vac diagram https://slantsix.org/forum/viewtopic.php?t=18417 |
| Author: | zorg [ Wed Jul 05, 2006 7:46 pm ] |
| Post subject: | vac diagram |
Where do the three lines from the vac amplifier go? Manifold vac, CCEGR, and ? 76 Dart, supersix. Thanks. |
| Author: | SlantSixDan [ Wed Jul 05, 2006 9:16 pm ] |
One small-diameter line goes from the amplifier to the EGR valve. One small-diameter line goes from the amplifier to the carburetor's venturi vacuum takeoff (located smack in the middle of the passenger side of the carburetor, not down low with the vacuum advance and PCV ports, nor up high with the float bowl vent port). Large-diameter line goes to manifold vacuum. The key is not getting those two small lines crossed up. |
| Author: | DusterIdiot [ Wed Jul 05, 2006 9:41 pm ] |
| Post subject: | Isn't that??? |
Quote: One small-diameter line goes from the amplifier to the EGR valve.
Isn't that one supposed to go to the temp switch then to the EGR so the EGR only activates after the engine is at operating temp? -D.Idiot |
| Author: | Reed [ Wed Jul 05, 2006 10:30 pm ] |
| Author: | mopardon [ Thu Jul 06, 2006 10:56 am ] |
| Post subject: | Re: Vac diag & hoses |
Clarification, please. I noticed that Zorg's car is a 76 Super which is a 2 bbl., correct? The diag. title (and thanks for the source) shows a 1 bbl. Any difference? I am fixing a 77 Super that shows (on fender diag. and in place) that the 3 hoses on this car go to the manifold, the vac. reservoir, and a small nipple low on the back of the 2 bbl. BBD. The larger nipple center left has the vac advance hose (OSAC valve not connected due to broken 'to carb' nipple on bottom.) Thanks |
| Author: | SlantSixDan [ Thu Jul 06, 2006 11:14 am ] |
| Post subject: | Re: Isn't that??? |
Quote: Quote: One small-diameter line goes from the amplifier to the EGR valve.
Isn't that one supposed to go to the temp switch then to the EGR so the EGR only activates after the engine is at operating temp? |
| Author: | Reed [ Thu Jul 06, 2006 11:58 am ] |
Quote: Clarification, please. I noticed that Zorg's car is a 76 Super which is a 2 bbl., correct? The diag. title (and thanks for the source) shows a 1 bbl. Any difference? I am fixing a 77 Super that shows (on fender diag. and in place) that the 3 hoses on this car go to the manifold, the vac. reservoir,
