| Original brakes? https://slantsix.org/forum/viewtopic.php?t=18447 |
| Author: | RossKinder [ Fri Jul 07, 2006 8:56 pm ] |
| Post subject: | Original brakes? |
What kind of brakes should one expect to find on an original '72 Challenger? |
| Author: | SlantSixDan [ Fri Jul 07, 2006 9:06 pm ] |
Hydraulic. |
| Author: | Bohmer2 [ Fri Jul 07, 2006 11:00 pm ] |
If you are asking disc or drum fronts, my 72 has drums all around. But there were options for disc fronts. |
| Author: | RossKinder [ Fri Jul 07, 2006 11:18 pm ] |
Quote: If you are asking disc or drum fronts, my 72 has drums all around. But there were options for disc fronts.
So this is the treasured E-body brakes A-body Slanters used to dream about . . . Thanks |
| Author: | RossKinder [ Fri Jul 07, 2006 11:19 pm ] |
Quote: Hydraulic.
Ever the optomist.
| Author: | Bohmer2 [ Sat Jul 08, 2006 5:38 am ] |
Actually, since there were far more a-bodies and the 73 up disc brake spindles work on either an a- or e-body most e-body guys grab the later a-body disc parts for up front. |
| Author: | RossKinder [ Sat Jul 08, 2006 8:02 am ] |
Quote: Actually, since there were far more a-bodies and the 73 up disc brake spindles work on either an a- or e-body most e-body guys grab the later a-body disc parts for up front.
Perhaps I misunderstood some things I've read. As I said, I was referring to Slanters - but I meant A-body Slanters. V_8 owners, especially with larger bodies, obviously want discs.
| Author: | RossKinder [ Sat Jul 08, 2006 5:42 pm ] |
I seem to have left out a detail. What prompted this thread/question was finding 10" front drums on a '72 Challenger. As of now I can't even find anyone who sells replacement 10" front drums.I don't know for sure, but I'm guessing the Challenger actually delivered with a 225 in it. Thanks |
| Author: | emsvitil [ Sat Jul 08, 2006 5:47 pm ] |
Did you try RockAuto? |
| Author: | RossKinder [ Sat Jul 08, 2006 5:51 pm ] |
Quote: Did you try RockAuto?
Yup. They have 10" rear and 11" front.Thanks |
| Author: | emsvitil [ Sat Jul 08, 2006 5:54 pm ] |
Go here: http://www.federalmogul.com/aftermarket ... ountry=USA Then under Catalogs, Make Model lookup.... Get a part number(s) then enter that part number at rock auto under part(s) number lookup. Sometimes you can find stuff at rockauto that way........... (they don't always have everything crossreferenced....) |
| Author: | RossKinder [ Sat Jul 08, 2006 6:29 pm ] |
Quote: Go here:
Thanks
http://www.federalmogul.com/aftermarket ... ountry=USA Then under Catalogs, Make Model lookup.... Get a part number(s) then enter that part number at rock auto under part(s) number lookup. Quote: Sometimes you can find stuff at rockauto that way........... (they don't always have everything crossreferenced....)
Well, horse feathers - and a side dish of chicken hair. Nice place and lots of fun, but they didn't have any drums listed, only studs, nuts and shoes - and info about when t o throw the drums away away, etc. (And I tried on each side of 1972.)Thanks |
| Author: | tophat [ Sat Jul 08, 2006 7:07 pm ] |
in this book http://i61.photobucket.com/albums/h56/t ... C00002.jpg it says 10 x 2 1/2 front brakes were avaible the part # BD60264 is listed for front drums. though they dont list diffrent #s for each side the same # is listed for a base 72 charger with 10 x 1/2 REMEMBER this is a 1989 parts book. but that # might help you in your search. the parts did exist at one time. someone may be able to convert that # for you to something. good luck |
| Author: | RossKinder [ Sun Jul 09, 2006 7:29 am ] |
Quote: in this book
Every little bit helps.http://i61.photobucket.com/albums/h56/t ... C00002.jpg it says 10 x 2 1/2 front brakes were avaible that # might help you in your search. the parts did exist at one time. someone may be able to convert that # for you to something. good luck Thanks |
