Proper spark plug selection is in question
https://slantsix.org/forum/viewtopic.php?t=18508
Author:  Bren67Cuda904 [ Wed Jul 12, 2006 9:18 am ]
Post subject:  Proper spark plug selection is in question
Someone recommended the NGK ZFR5N plug with gasket removed. The Bosch 4218 plugs are a taper fit. The Bosch was looked up at one of the local part stores. ( They maybe wrong) Are you saying you can remove the gasket on the NGK plug and get it to seal in a taper fit hole. I don't think this in correct.
Is my 67 head a taper fit or gasket fit type. I do have plug tubes.
Author:  '74 Sport [ Wed Jul 12, 2006 9:33 am ]
The taper fit plugs came in later years. I don't know when it began, but my son's '74 has the "drool" tubes, so it was after that.
Jerry
Author:  slantvaliant [ Wed Jul 12, 2006 9:56 am ]
This chart shows the plug and other head changes.
http://www.slantsix.org/articles/parts-matrix/jpg.htm
Also, read this thread:
http://www.slantsix.org/forum/viewtopic ... tolite+985
Author:  Slant n' Rant [ Wed Jul 12, 2006 12:27 pm ]
The cut off year is 1974, 75 and up use the taper seat and can't use the 985's or ZFR5n's :x . I had a 2.5L ram van that I managed to find Pontiac spark plugs that fit that had a longer head so there might be something else out there for later heads.
Author:  Bren67Cuda904 [ Wed Jul 12, 2006 1:45 pm ]
I used the ZFR5N plugs. These are the plugs that where removed. (Autolite platuim) #2 and #6 look a bit different than the others. This motor has either 22,000 miles or 122,000 miles. (odometer rollover?) Your thoughts on the plugs.
http://www.renaissanceracing.com/images ... gsfull.JPG
Author:  Bren67Cuda904 [ Wed Jul 12, 2006 1:47 pm ]
Oh and where do I get new plug tube O-rings?
Author:  Larry E Gee [ Wed Jul 12, 2006 2:48 pm ]
Fel-pro ES12794
Autozone
Got mine @ a year ago
Author:  Jeb [ Wed Jul 12, 2006 3:14 pm ]
Looks like your engine is running a little on the lean side. What is your timing set at? They are supposed to be a light tan color.
Author:  Bren67Cuda904 [ Wed Jul 12, 2006 8:54 pm ]
have not checked timing. I have noticed a ping around 60 - 70 mph under light acel, but goes away as more gas is given. Running a 185 degree thermostat.
