It is currently Sat Nov 21, 2026 11:48 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Sat May 11, 2002 7:12 pm
Just an update on my project. I'm almost finished creating the drive system and the first draft of the Eaton M90 blower mounting bracket. The water pump and alternator will now run off the inner crank pulley sheave (new alt mounting bracket and altered fan pulley mounting further up the hub.)The power steering pump will run off the middle sheave (modified bracket). I'm using a cast /6 aluminum manifold and a tube from the T-bird as the basis to fabricate the intake. I've mocked up a replica of the fuel rail (old hocket stick)with old injectors so that I keep my efi area free. I'm not far from putting it all on a website for easier access.
