It is currently Thu Nov 26, 2026 12:23 am
PostPosted: Wed Sep 27, 2006 6:30 pm
Just got my pistions from Venolia and was going over the data sheet and I think they ^&*( up on the pin bore they went .0901. Is that ok or is that .001 go to make impassable to get a pin with out having them made?
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Wed Sep 27, 2006 6:51 pm
The pin itself is supposed to be .9012". The pin hole obviously has to be larger. When I spoke with Venolia they told me that if I didn't order pins (I did) the pistons would need to be honed by my machinist to fit the stock pins.
PostPosted: Wed Sep 27, 2006 7:01 pm
OK thank you They told me that they didnot have a pin that big. So I am in the clear then. I was about to have a heart a tack. :P :lol:
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Thu Sep 28, 2006 12:44 am
If you dont mind how much is a set a Venolias these days.
Jess
PostPosted: Thu Sep 28, 2006 1:10 am
My set with pin oilers, .875" tapered wall 4340 wrist pins, pin fitting and double spirolocks was just over $500 shipped. The slugs are only $54.40 each.
