| 198 SL6 Dyno Results = 253 HP & 267 ft.lbs! https://slantsix.org/forum/viewtopic.php?t=18685 |
| Author: | Doctor Dodge [ Thu Jul 20, 2006 10:23 am ] |
| Post subject: | 198 SL6 Dyno Results = 253 HP & 267 ft.lbs! |
Once upon a time I worked with a person in Texas on a 198 SL6 engine build-up. As these types of projects seem to go... things took longer then ever expected but low and behold, he just Dynoed the engine and boy, it sure makes good power! Here is a copy of the Dyno Results On a separate dyno data page, it was good to see that the Dutra H-Pac manifold used had cylinder temps that were with-in 100 degrees, between all cylinders, that is great fuel mixture distribution for that manifold. DD Another dyno photo [/i]
| Author: | slantvaliant [ Thu Jul 20, 2006 11:02 am ] |
Abilene? Hmmmmmm ..... Good numbers, Doc! |
| Author: | gmader [ Thu Jul 20, 2006 11:23 am ] |
How did they get the VE so high? Was this due to the Hyperpack intake solely? How much head work was done on this as well? Great build up! Greg |
| Author: | Joshie225 [ Thu Jul 20, 2006 2:25 pm ] |
Those are good numbers. Big valves too. They use a big block exhaust valve for the intake? The carb is mounted with the primaries toward the head. Is this best for mixture distribution and would you expect similar results with the Clifford made manifold? I'm planing on the same carb and intake for my 170 build. |
| Author: | Doctor Dodge [ Thu Jul 20, 2006 11:47 pm ] |
Quote: How did they get the VE so high? Was this due to the Hyperpack intake solely? How much head work was done on this as well?
Yes, 127% VE on a NA engine is impressive.... the ram manifold really works.Great build up! Greg We are tring to figure-out why the engine's VE falls off in the 2700 to 3000 RPM range. I wish I was at they dyno session to do some advance curve tests to see if the problem is inside the distributor or if it is linked to something else. DD |
| Author: | Eric W [ Fri Jul 21, 2006 12:28 am ] |
Impressive numbers for sure! Anybody else notice the upper coolent hose (looks like a cheap-o universal type) is pinched? |
| Author: | Guest [ Fri Jul 21, 2006 7:20 am ] |
Wow, that's 1.23 HP/cubic inch. Great naturally aspirated numbers better, in fact, than the 1.19 HP/cubic inch in my 2007 Honda Fit VTEC 1.5 engine with all of its modern technology. |
| Author: | DusterIdiot [ Fri Jul 21, 2006 7:22 am ] |
| Post subject: | Yes! |
Quote: Yes, 127% VE on a NA engine is impressive.... the ram manifold really works.
That explains the sudden rush of power I get between the 2500 and 4000 range on my car. It's nice to see an actual number instead of "Well it, picked up an extra cylinder about here..."-D.Idiot |
| Author: | GuyLR [ Fri Jul 21, 2006 10:01 am ] |
Quote: Wow, that's 1.23 HP/cubic inch. Great naturally aspirated numbers better, in fact, than the 1.19 HP/cubic inch in my 2007 Honda Fit VTEC 1.5 engine with all of its modern technology.
Yeah but your Fit VTEC is sewing machine smooth, probably gets 35 mpg on regular and is CARB rated as a LEV-2. That Slant would idle like a 64 GMC V6 with one spark plug fouled, get 8 mpg on Premium and don't even think about getting it smogged. Modern tech isn't so bad.
| Author: | Joshie225 [ Fri Jul 21, 2006 11:16 am ] |
Now that's funny. Also most performance engine dynos are corrected to a different factor than the OEMs use. If the slant test was corrected to SAE J1349 then the numbers would be comparible. |
| Author: | 440_Magnum [ Sat Jul 22, 2006 3:33 pm ] |
Quote: Yeah but your Fit VTEC is sewing machine smooth, probably gets 35 mpg on regular and is CARB rated as a LEV-2. . But its still a soulless imported generic plastic sh*tbox Quote:
That Slant would idle like a 64 GMC V6 with one spark plug fouled, get 8 mpg on Premium and don't even think about getting it smogged.. So you're saying it has character. And smogging is a non-issue, its old enough it doesn't have to be smogged. Quote: Modern tech isn't so bad. And it aint good either. Its just a necessary evil so the un-interested masses can have transportation appliances and the rest of us can play with real cars and still breathe the air. |
| Author: | 440_Magnum [ Sat Jul 22, 2006 3:44 pm ] |
Quote: Quote: How did they get the VE so high? Was this due to the Hyperpack intake solely? How much head work was done on this as well?
| Author: | GuyLR [ Sat Jul 22, 2006 8:06 pm ] |
Quote: Quote: Yeah but your Fit VTEC is sewing machine smooth, probably gets 35 mpg on regular and is CARB rated as a LEV-2. . But its still a soulless imported generic plastic sh*tbox Quote:
| Author: | 440_Magnum [ Mon Jul 24, 2006 8:22 am ] |
Gosh, no need to go all Ludite on us.Quote: Why C&D had it at 16.7 and 81 mph in the quarter which is quicker by 0.9 second than the '66 Formula S Barracuda they tested in their June '66 issue. I'd rather drive the Barracuda any day. A Honda might out-run it (unless you give the Barracuda a set of radials), but it'll never out-cool it under any circumstances. Quote: That's at least a little bit of character for 15 G's don't ya think?:lol:
If someone GAVE me one, I'd sell it and spend the 15 G's on gas for my Polara and Coronet R/T. |
| Author: | Guest [ Mon Jul 24, 2006 11:11 am ] |
I'd love to drive my Valiant EVERY day, but driving it into the District of Columbia every day to work would probably be a bad idea. My good friend in the car business says "there's an ass for every seat" so whatever works for you is cool with me. Still, a naturally aspirated 1 1/4 HP/C.I. in what many folks thought of as a boat anchor is impressive to me. GuyLR - thanks for the back-up numbers. I think the Fit Sport will do well for Honda. But yes, it is an economical and reliable appliance to get back and forth to work 80 miles a day while leaving more money and time for my Mopar. E'nuff about that! |
