741 -8 3/4 gear selection
https://slantsix.org/forum/viewtopic.php?t=18689
Page 1 of 1
Author:  featherduster76 [ Thu Jul 20, 2006 3:05 pm ]
Post subject:  741 -8 3/4 gear selection
Is either a 4.30 or 4.56 ring and pinion available for the 741 casting 8.75 rear? Most of the deep ratios I spot are for the 489 casting....
Author:  Lars [ Thu Jul 20, 2006 3:14 pm ]
The only aftermarket ratios I've seen for the 741 case are 3.55 and 3.73 at Randy's.
Author:  Joshie225 [ Fri Jul 21, 2006 12:56 am ]
You'll be a lot better off picking up a 489 3rd member. I got a 3.23 open one at a local self-serve yard for $50 recently. I just wish I could have found some 3.55s, but 3.23s are ok too and I didn't have 3.23s either.
Author:  Ron Parker [ Mon Jul 24, 2006 5:08 pm ]
Fetherduster76 find a 742open or 489 open out of a b bodycar they should be cheep. Ask for a 66 and up. Then your gear slection is what you want. Thanks Ron Parker :D
It Aint Over Until I Win
