It is currently Sat Oct 10, 2026 5:34 pm
PostPosted: Thu Jul 20, 2006 4:02 pm
In a typical performance Slant Six build-up which type of piston ring is prefered? Moly coated, chrome faced or cast iron?
Now, for turbo applications is it different?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Jul 20, 2006 5:46 pm
I have used moly on my motors with good results.
PostPosted: Thu Jul 20, 2006 6:22 pm
From what I understand, cast iron rings will work ok, though they're not the most wear or scuff resistant. Chrome actually gives the best wear and scuff resistance; so much that on most street cars they will never even "wear in" and you'll end up w/ bad blowby. Moly kind of walks the line between the two, striking a good balance.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Thu Jul 20, 2006 11:54 pm
With high compression, NOS or Turbo race engines, the moly can give you trouble, I have seen the moly "peel-off" the rings.
On street engines, the moly coated rings work well.
Be sure the cylinders are honed to match the rings you plan to use, moly rings need a smooth hone RMS.
PostPosted: Fri Jul 21, 2006 7:30 am
When I ordered my engine rebuild kit I requested moly rings. The salesperson said they didn't have them in stock, but they had the cast iron rings. He asked if my cylinders were honed for moly rings, a question I have never heard. Doctor Dodge points out in this post that there is a difference. I honed my own cylinder walls with 100, then 280 grit spreading type hone. I took the cast iron rings and they seem fine on my stock 225 after 800 miles. I'll have to confirm with a compression test after my first oil and filter change.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 102 guests
