It is currently Tue Nov 17, 2026 9:29 pm
PostPosted: Mon Jul 24, 2006 10:14 am
Is this common? It cracked where the key slot is, also had no bolt holding it on ..........animals everywhere.
I notice repair sleeves, but they won't fix this. So, I need a balancer key and bolt.. and a repair sleeve? Anyone want to turn doorstop into 35$
PostPosted: Mon Jul 24, 2006 10:48 am
No, this isn't common. Most slants don't have a bolt retaining the balancer, but you can install one. If your balancer broke at the keyway during operation I'd inspect the crank carefully.
You're right about the repair sleeve. The sleeves are only to repair seal wear.
PostPosted: Mon Jul 24, 2006 1:20 pm
TBI slant six? Tell me more........
PostPosted: Mon Jul 24, 2006 1:31 pm
Yeah, once you get over 200 posts that will appear below your screen name too.
PostPosted: Mon Jul 24, 2006 2:41 pm
I thought you had an injected 225....
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 4 guests
