| BBD accel. pump cup lube? https://slantsix.org/forum/viewtopic.php?t=18731 |
| Author: | mopardon [ Sat Jul 22, 2006 4:11 pm ] |
| Post subject: | BBD accel. pump cup lube? |
Greetings - The FSMs that I ordered, and which might or might not include the info. that I need, won't be here for several days. In the meantime, I'm ISO what other BBD /6rs use to 'lightly lubricate the cup' that will not react with fuel or the cup composition. If anything. Thanks and regards. |
| Author: | Reed [ Sat Jul 22, 2006 4:16 pm ] |
Gasoline. |
| Author: | SlantSixDan [ Sat Jul 22, 2006 6:00 pm ] |
Oil of most any type you've got (engine oil, trans fluid, P/S fluid, 3-in-One) will do fine to soften up the leather so you can flare-out the cup prior to its installation. Gasoline, carburetor cleaner, brake cleaner, penetrating oil, WD40, etc. isn't what is wanted. |
| Author: | Reed [ Sat Jul 22, 2006 6:02 pm ] |
Oh. I thought he was talking about lube for inital carb assembly. Sorry. |
