It is currently Tue Oct 13, 2026 8:18 am
PostPosted: Sat Jul 22, 2006 3:45 pm
Car Model: 62 Lancer GT
My 66 Darts radiator is shot. I don't need an exact replacement. But I would like to be as bolt in as possible. I do want the flexibility of using an automatic or standard trans. and to be able to use the same radiator if I decide to go to a v8 at some point. Any recommendations?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Sun Jul 23, 2006 8:03 am
I put a 1979 Volare radiator in my 65 Cuda. I think I had to redrill the holes because the radiator sat to low with the stock holes. Other than that it is a perfect fit. Mine is the /6 radiator. I have had two in there now. I would expect the 66 Dart to use the same rad.
The first was a JY radiator and when it gave up I bought a new one part #525. It might be a Modine number but I am not sure of that.
PostPosted: Sun Jul 23, 2006 8:14 am
Car Model: 1974 W100; 72 Dart
that one will work, so will the 67 up a-body rad. both available from parts america or autozone....
sb
PostPosted: Sun Jul 23, 2006 8:29 am
if you might go to a V8, start off with a heavy-duty radiator to begin with. Spectra premium CU526 is a 22" wide A-body radiator. Bottom hose outlet is in the lower right corner, so that'll work fine with either a '70-up slant-6 lower radiator hose, or a '70-up V8 water pump housing and lower hose. Upper hose outlet is closer to the top-left than to the top-right, so you'd have to find a top hose that'll get you where you need to go (shouldn't be too hard, you can either keep the \6 vertical-outlet water neck or change to the V8 straight-type water neck). Alternatively, a radiator shop can move the top outlet for you.
Be careful when you shop; new-aftermarket radiator quality is a real crapshoot these days. Pick a major North American brand (Modine or Spectra Premium); avoid the off-brand junk coming in from China (Ready-Rad, etc.). The Chinese stuff costs a lot less...for a really good reason. It doesn't work well or last long.
Users browsing this forum: Amazon [Bot] and 10 guests
