It is currently Tue Oct 13, 2026 4:25 am
PostPosted: Sun Jul 23, 2006 10:46 am
I have an offenhauser single quad intake manifold that I'm putting into a '73 Dart. The car has an automatic transmission and Summit Racing mentions a special kit for automatics which must be ordered separately.
What part number is this kit and is there someplace I can get a good price on it?
I also have to replace the exhaust manifold. Should I go with a stock replacement? I don't think I have room for headers with the stuff for the power steering and automatic transmission in the way.
The engine is bored .030 and it also has a comp cams cam.
PostPosted: Sun Jul 23, 2006 12:57 pm
Car Model: 1974 W100; 72 Dart
the part # you need is 5270-A. check here:
www.offyparts.com
or type that # in over at summit.
if you want a replacement (new) manifold go here:
http://www.1aauto.com/1A/ExhaustManifolds/Dodge/Aspen
its a really nice piece and even comes with new triangle washers.
in that car there is no reason not to use Dutra Duals, even with power steering....if i am thinking right.
http://www.slantsix.org/articles/exhaus ... d-mods.htm
that seems daunting at first, but once you cut the front leg off, you can braze it together with stuff you can buy at home depot.
sb
Users browsing this forum: DuckDuckGo [Bot] and 15 guests
