| magnum 500 sizes? https://slantsix.org/forum/viewtopic.php?t=18807 |
Page 1 of 2 |
| Author: | 64'4$peed [ Tue Jul 25, 2006 3:49 pm ] |
| Post subject: | magnum 500 sizes? |
were these rims ever available in the SBP? and were they ever available as a 14" wheel with the SBP thanks |
| Author: | SlantSixDan [ Tue Jul 25, 2006 5:09 pm ] |
| Post subject: | Re: magnum 500 sizes? |
Quote: were these rims ever available in the SBP?
Nope.
| Author: | 65 dartman [ Tue Jul 25, 2006 6:14 pm ] |
But if you change over to LBP discs in your 63-72 A Body, they look absolutely great! |
| Author: | Commando66 [ Mon Dec 03, 2012 9:43 pm ] |
I know this is an old thread, but are these small bolt magnum's?
| Author: | Joshie225 [ Tue Dec 04, 2012 12:17 pm ] |
Small bolt pattern Magnum 500 wheels still do not exist. |
| Author: | Commando66 [ Tue Dec 04, 2012 3:44 pm ] |
The wheels that I have in the picture above are small bolt pattern. There is a picture of the Group 44 Trans Am Dart with wheels like these. |
| Author: | Doctor Injector [ Tue Dec 04, 2012 11:09 pm ] |
| Post subject: | small bolt Magnum rims |
Is there a part number on the rim and is there a Chrysler Pentastar stamped near the valve stem hole. I have never heard of a 5 on 4 bolt pattern factory Magnum rim |
| Author: | Mroldfart2u [ Wed Dec 05, 2012 4:56 am ] |
I'd bet the wheel in the pic is an aftermarket wheel. Has the looks of a GM wheel. (cant remember what those were called Rally II's maybe?) |
| Author: | Commando66 [ Wed Dec 05, 2012 6:49 am ] |
There is no pentastar. I just thought they would be good on a 66 era Trans Am type car. |
| Author: | Mroldfart2u [ Wed Dec 05, 2012 9:45 am ] |
Quote: There is no pentastar. I just thought they would be good on a 66 era Trans Am type car.
They would look good on a T/A styled car.....
| Author: | MichaelS [ Sat Dec 22, 2012 8:16 am ] |
Did the Tulius group 44 dart use small bolt wheels for TA racing? I have seen pictures of it with those style wheels also. In the first season of TA I think they had to use stock wheels. |
| Author: | Romeo Furio [ Sat Dec 22, 2012 9:08 am ] |
There is a 5 bolt 100 mm wheel(GM) that LOOKS just like the 500's. It LOOKS like small bolt pattern. It don't fit. |
| Author: | Commando66 [ Sat Dec 22, 2012 10:21 am ] |
I have bolted these on a Valiant. They are 4" bolt pattern. Maybe I should convert my Barracuda back to small bolt pattern and use them. |
| Author: | Romeo Furio [ Sat Dec 22, 2012 2:31 pm ] |
Big debate between 100mm and 4'' Some say yes some say no.Like oil and oil filters..I should have said I have not tried(only read) therefore should have no opinion. |
| Author: | Mroldfart2u [ Sun Dec 23, 2012 12:12 pm ] |
hmmm 100mm= 3.94"..... so its not quite 4", and on wheel I think I would like it to be right on... M2C |
| Page 1 of 2 | All times are UTC-07:00 |
