| A-904 Clutch Packs https://slantsix.org/forum/viewtopic.php?t=18843 |
| Author: | bwhitejr [ Thu Jul 27, 2006 3:56 am ] |
| Post subject: | A-904 Clutch Packs |
In my new A-904 clutch pack there are waffle disks and straight cut disks. Which ones go in the front drum and which ones go in the rear drum? BTW, I noticed that the waffle disks are 0.086 thick and the straight cut disks are 0.062 thick. I looked up the Raybestos part number that Mopar Performance sent me in the A-904 Performance Rebuild Kit and it was for a 72 and Up tranny. Mine is a 69. I don't know that it matters, although Raybestos has a clutch pack for 60-87. I even see where you can put thinner disks in a stock drum, so you can get a total of 5 in there. Help! I am over my head. bwhitejr |
| Author: | LUCKY13 [ Fri Jul 28, 2006 11:46 am ] |
The clutchs that have the groves/slots are the front drum. I believe they are the think ones. There is alot of info about adding clutches to the 904. It gets tricky but all the anwsers are out there. Just do a seach on google and you will find them. |
| Author: | Slant Cecil [ Fri Jul 28, 2006 1:38 pm ] |
The waffles are for fluid escape when the front clutch pack engages on the 2-3 shift. Since the rear pack is always engaged in all 3 forward gears, no fluid movement grooves are needed. |
