Underdash Harness
https://slantsix.org/forum/viewtopic.php?t=18879
Author:  dakight [ Fri Jul 28, 2006 4:43 pm ]
Post subject:  Underdash Harness
The harness under the dash of my 62 Valiant has been fried pretty good. I have one out of a 62 Lancer but it is hard and brittle, most likely unusable. To cut to the chase, I might be able to get one from a 63 Valiant and I'm wondering how difficult it would be to use it in the 62.
Author:  SlantSixDan [ Fri Jul 28, 2006 6:07 pm ]
That wouldn't be too difficult of a swap. You may have to lengthen some wires and/or change a few terminals. You'll definitely want to add more circuit protection than came from the factory in '62 or '63 (no main fuse or fusible link, even!).
Author:  dakight [ Fri Jul 28, 2006 7:23 pm ]
Thanks Dan. At $20.00 it sure beats a Ron Francis job even if I have to spend a few more to modernize it. FWIW I intend to eliminate the high current loop to the ammeter and install a volmeter and oil pressure gauge in a pod below the dash. I might also update the fuse panel as I will need to add some circuits for an audio system and AC. From what I've seen the ammeter loop is the source of a lot of meltdowns anyway.
Author:  VDART [ Fri Jul 28, 2006 7:24 pm ]
Post subject:  harness
Hey David I think I can help-- & at one time I had a 62 harness I do know that I have a 63 saved-- i'll check & see how they compare, Lawrence
Author:  dakight [ Fri Jul 28, 2006 7:27 pm ]
Cool, thanks!
Author:  SlantSixDan [ Fri Jul 28, 2006 7:43 pm ]
I prefer to have a working ammeter (I regard voltmeters are considerably less useful), and I'm also sort of a hardnose about original equipment working correctly. I may look into doing this slick mod.
Author:  dakight [ Sat Jul 29, 2006 5:36 am ]
Interesting concept. I downloaded the referenced pdf and will have a closer look at it later.
Author:  KBB_of_TMC [ Mon Jul 31, 2006 9:30 am ]
Post subject:  article
A copy of keeping the article is now at
http://www.tidewatermoparclub.com/TECH/ ... shunt5.pdf
