| Intake Manifold removal https://slantsix.org/forum/viewtopic.php?t=18900 |
| Author: | Highway [ Sat Jul 29, 2006 12:27 pm ] |
| Post subject: | Intake Manifold removal |
Is it possible to remove only the intake manifold without removing the exhaust manifold? The vacuum valve on the rear of the intake manifold was broke and leaking. When I tried to remove the valve, it snapped off like a twig. It had the frailty of a saltine cracker. Anyways, now I need to remove the intake manifold, tap out the hole and rethread it for a new valve. Any tips on an easier removal and installation would be greatly appreciated. btw - I did read the article on manifold removal but it focuses on mainly exhaust manifold removal. |
| Author: | Reed [ Sat Jul 29, 2006 12:33 pm ] |
This will depend largely on wether or not you have a stud or a bolt on the inboard nut fastening thre intake and exhaust together. Both were used from the factory. If you have a stud, forget it, but if you have a bolt you *may* be able to sneak just the intake off. Of course, the only effort you will save is removing the two outboard most nuts on the exhaust manifold. |
| Author: | Highway [ Sat Jul 29, 2006 1:26 pm ] |
In that case might as well pull both. Thanks Reed and wish me luck. |
| Author: | SlantSixDan [ Sat Jul 29, 2006 6:12 pm ] |
The practical answer is "No". You will have to replace the manifold-to-head gasket as soon as you pull either manifold, so you must pull both. |
| Author: | argentina-slantsixer [ Sat Jul 29, 2006 7:13 pm ] |
I always combine exhaust and intake business at the same shop (my headers shop, they're cool enough so everytime I want to try something diffrent on the intake I go to them so they reseal the whole thing.) I end up loosing no time guessiing at exhaust or intake vacuum leaks.. straight to the business of tuning up the diffrent carb/s. 99% they don't charge me but I solved the emarrasement to myself tipping them big time... |
| Author: | Highway [ Mon Jul 31, 2006 6:15 am ] |
| Post subject: | Follow up: |
Mission Successful! In ten years I have never had the manifolds off. No broke studs and everything sealed back up good. I wanted to replace all the studs but couldn't find any on a Sunday. Oh well, building a new engine this spring. |
