It is currently Fri Nov 06, 2026 10:15 am
 Post subject: Valve Cover
PostPosted: Thu Aug 03, 2006 5:48 pm
I bought a valve cover for my Slant six but have a minor problem.
MY stock cover has three holes in it
1x oil cap
1x PVC Valve
1x Breather.
But the new one has 2 holes
1x Breather
1x Hole(maybe pvc valve or oil cap)
Am I ratarted and just dont know what to hook up or do i need to get another hole drilled?
Stock 68 dart 225.
PostPosted: Thu Aug 03, 2006 6:55 pm
Ohh, you bought one of those aftermarket chrome valve covers didn't you? one hole is for pcv and the other is for crankcase ventillation. You will have to add some baffles to it also. I just add I have one of these on my Duster. Don't overtighten it and it won't leak. Here is a pic of my valve cover after I added the baffles. Drill a couple of small halfcircles in the baffles so any excess oil can drain away. I just add my oil through the breather hole. Buy a funnel.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Thu Aug 03, 2006 8:33 pm
Yargh, it's those poorly-built Chinese chrome valve covers again. See here.
 Post subject: Re: Valve Cover
PostPosted: Thu Aug 03, 2006 8:45 pm
1x oil cap
1x PVC Valve
1x Breather.
1x Breather
My stock cover has two holes
1x PCV Valve
1x Breather/Oil Cap
PostPosted: Thu Aug 03, 2006 9:02 pm
Right, but yours is a pre-'70, while the original poster's is obviously a '70-up application.
PostPosted: Fri Aug 04, 2006 5:02 pm
I'm actualy a 68
and its an original valve cover and engine I checked the build sheet againsgt the engine and its true and spoke with all the owners back to 68 and nothing has been changed in the car besides the wheels.
Stock 68 dart 225.
PostPosted: Fri Aug 04, 2006 7:09 pm
Nope! You and the previous owners are mistaken. '68 covers had one hole, at the rear, with a grommet, for a PCV valve, and one "chimney", at the front, with a breather/oil fill cap.
There were no slant-6 valve covers with three holes before 1970. The '70-'80 valve covers bolt directly onto the '60-'69 slant-6s, so it would be easy to make such a swap without any evidence of modification except for the later-type cover itself.
PostPosted: Fri Aug 04, 2006 9:32 pm
ok then i have the right valve cover.
its not a cheepie off ebay it was from national moparts.
Stock 68 dart 225.
Users browsing this forum: Ahrefs [Bot] and 14 guests
