| Quest. re: BBD pump squirt & fuel routing. https://slantsix.org/forum/viewtopic.php?t=18950 |
| Author: | mopardon [ Tue Aug 01, 2006 2:12 am ] |
| Post subject: | Quest. re: BBD pump squirt & fuel routing. |
My FSM & other books still twisting in the wind somewhere. I looked in history here - 109 hits! Read many of them. 1) Can someone point me to exactly where the visible pump shot should be coming from in the carb throat. With the engine warm, and off, I see vapor coming up past the throttle plates. Also, droplets on the tops of the plates, but no shot. The prev. posts about visible 'squirts' have compelled me to find out. 2) Is there a link to a site that has a layman's explan. of the BBD fuel routing (idle circuit, pump, rods, jets, venturi, etc.) I have the views/lists/ adjustments from the kit. They look the same as posted previously here. This might be in FSM but I don't know. Thanks very much in advance. Don |
