It is currently Sat Nov 07, 2026 8:36 pm
PostPosted: Tue Aug 01, 2006 7:55 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
I've got a '71 D100, so there's some room up front--would a five blade fan w/thermostat bolt right up?
Here's what I'm looking at:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWA%3AIT
Thanks,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Tue Aug 01, 2006 8:28 am
Yep, if you have the front-to-back clearance, which in a truck you probably do, it'll bolt right up. You may want to install a new fan clutch rather than an unknown used one.
PostPosted: Thu Aug 03, 2006 7:02 pm
Thanks,
Joe
That's the same fan that Mopar Perfomance sells as a cooling upgrade for vintage muscle cars. Its also the *stock* fan for an 83 Diplomat with a slant six (among others). It does cool well, I run one on my '69 440 Magnum (in a Coronet convertible) and it cools substantially better than the original 7-blade fan. More blades is NOT always better. With fans the general rule is more blades can push air across a bigger pressure diffferential (in other words, move air through a heavy restriction), but fewer blades will move a bigger volume of air if there's not much restriction to flow, and will take less power to do so. If you look at modern large home air-conditioner condensing units you notice that a lot of them have only 2- or 3-bladed fans even for 4 and 5 ton units.
PostPosted: Fri Aug 04, 2006 7:43 am
Thanks for the tips, guys. Looks like a five-bladed fan is in my future.
Joe
Joe Hoppe
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 4 guests
