| hard time finding rotors https://slantsix.org/forum/viewtopic.php?t=18979 |
| Author: | stolan83 [ Wed Aug 02, 2006 5:40 pm ] |
| Post subject: | hard time finding rotors |
Does any one know were to get cross drilled or slotted rotors for the kh 5 on 4 |
| Author: | dakight [ Wed Aug 02, 2006 5:58 pm ] |
| Post subject: | Re: hard time finding rotors |
Quote: Does any one know were to get cross drilled or slotted rotors for the kh 5 on 4
You're doing well just to find rotors, let alone cross drilled and slotted.
| Author: | Joshie225 [ Wed Aug 02, 2006 8:40 pm ] |
Good God why? It's marketing hype. The only vehicles that use cross drilled rotors from the factory have oversized rotors to offset the loss of mass. Taking heat sinking mass from stock sized brake rotors on any Chrysler product to include the Viper is asinine. If you want cooler brakes you're going to have to duct air to them. Painting your brakes bright colors and drilling pretty patterns of holes in the rotors should be accompanied by a sideways hat and a sign from Bill Engvall.
| Author: | SlantSixDan [ Wed Aug 02, 2006 8:43 pm ] |
I wasn't going to say anything, but these other guys are right. There is no valid reason to drill or slot your rotors. |
| Author: | Caliente Valiante [ Wed Aug 02, 2006 8:52 pm ] |
Unless you like cracked rotors (think "Connect-the-dots") peeking out from your rims...or unturnable ones! |
| Author: | Joshie225 [ Wed Aug 02, 2006 9:28 pm ] |
Quote: I wasn't going to say anything, but these other guys are right. There is no valid reason to drill or slot your rotors.
So you want to play good cop for a while and I'll take bad?
| Author: | stolan83 [ Sat Aug 05, 2006 10:07 pm ] |
OK OK I get the point |
