radiator/tranny line fittings
https://slantsix.org/forum/viewtopic.php?t=18986
Author:  Pierre [ Wed Aug 02, 2006 8:02 pm ]
Post subject:  radiator/tranny line fittings
Was making a shoping list to get parts for converting hard tranny lines to stainles wraped rubber hose with teflon liner - when I realized, the threads on radiator and tranny are 5/16" NPT, not the 1/4". I can't find any 5/16"NPT male to -6an (or any an size for that matter) anywhere.
Anyone seen these before, or am I going to have to get creative?
Author:  emsvitil [ Wed Aug 02, 2006 8:25 pm ]
Sure it's NPT?
Never heard of 5/16 NPT....
Author:  Pierre [ Wed Aug 02, 2006 8:33 pm ]
Fairly sure... 5/16" line, 5/16" npt. I found 5/16" npt to 5/16" 45deg flare fittings at Orchard hardware store (same as stock ones on the car). Thats a replacment (modine brand I think?) radiator so I'm fairly sure its standard for the application
Author:  emsvitil [ Wed Aug 02, 2006 8:37 pm ]
I was looking, and 5/16 line wasn't with a 5/16 fitting. (forgot what size)
Anyway, check this out:
http://www.machinedesign.com/ASP/viewSe ... =57454&amp
Author:  Pierre [ Wed Aug 02, 2006 8:53 pm ]
Fitting was labled 5/16" NPT x 5/16" Flare and it looked, fit and functioned as normal, direct replacment for the stock ones I took off the car. Only reason I took stock ones off was because the part where wrench grips was starting to round.
Author:  emsvitil [ Wed Aug 02, 2006 9:44 pm ]
http://www.anplumbing.com/
You might be able to find if it exists...........
then you have the problem of getting it. :wink:
Author:  Pierre [ Wed Aug 02, 2006 9:54 pm ]
Thanks for that link! Everything in one spot, sweet.
I was going off memory. It was getting on my nerves so I just went out in the dark and pulled fitting out - turns out it was 1/8" NPT x 5/16" flare. Could of sworn the package said 5/16"NPT x 5/16" flare. Oppsy. Come to thinl of it, 5/16" NPT would be quite big.
