| holley 2300 https://slantsix.org/forum/viewtopic.php?t=19028 |
| Author: | DustedIn05 [ Sat Aug 05, 2006 9:17 am ] |
| Post subject: | holley 2300 |
I've had a super six/dutra dual setup for a while. It might be a little while before i take the engine out for a rebuild, and have the body work done, so i'm planning on putting them in next weekend. So my question is: If i get a holley 2300 350 cfm carb and the mr gasket adapter #1937 adapter plate, does the standard super six kickdown linkage work? Thanks, Jay |
| Author: | Bentsix [ Sat Aug 05, 2006 10:42 am ] |
I have been running a super six with a 500cfm 2300 for about 2 years. It is on my daily driven 73 Valiant. I am running the stock throttle cable and stock 1 barrel kickdown with no problems. Motor is stock internally, with Clifford shorty headers, dual exhaust and Flowmaster mufflers. I am currently building up a .60 over slant to replace the stock piece. |
| Author: | DustedIn05 [ Sun Aug 06, 2006 7:04 am ] |
Bentsix, Did you have to modify the stock kickdown at all to make it work? If not, that's great news. Thanks |
| Author: | Bentsix [ Wed Aug 09, 2006 4:49 am ] |
No mods, just extended the rod all the way out, shift points are good - no problems. hope it works for you. |
