| Redline? https://slantsix.org/forum/viewtopic.php?t=19043 |
Page 1 of 2 |
| Author: | carvel [ Sun Aug 06, 2006 11:42 am ] |
| Post subject: | Redline? |
On a 225 what is the redline or rpm max that you dont want to exceed? i have one in my boat and im not sure.... i can go a little past 4000 rpm is this to much? or can i go further? |
| Author: | 66Dart4Me [ Sun Aug 06, 2006 12:41 pm ] |
well keep going until it flys apart, then when you put a new motor in it, don't go that far and you should be fine. |
| Author: | emsvitil [ Sun Aug 06, 2006 1:30 pm ] |
A stock 1bbl 225 will run out of breath before redline............. A little past 4000 is no problem. |
| Author: | panic [ Sun Aug 06, 2006 4:14 pm ] |
And, again, a complete waste of my time. |
| Author: | carvel [ Sun Aug 06, 2006 4:30 pm ] |
its a stock 225 1 bl can i go to 5000 rpm? in a boat |
| Author: | Joshie225 [ Sun Aug 06, 2006 4:43 pm ] |
Quote: its a stock 225 1 bl can i go to 5000 rpm?
You'll never get there if the prop is properly matched to the engine and hull combination.
in a boat |
| Author: | slantzilla [ Sun Aug 06, 2006 10:26 pm ] |
Stock 225 1 bbl is sucking wind at 4200. |
| Author: | Eric(Shivadart) [ Mon Aug 07, 2006 6:07 am ] |
my slant when it had the 1 barrel was useless at 4,000 RPM. |
| Author: | 75duster [ Tue Aug 08, 2006 8:09 am ] |
i can rap mine out to 5000 but its pretty much useless past 4250,just knowing i can do highway speeds in first is kinda cool though(2.76 rear gear) :D :twisted: |
| Author: | Ron Parker [ Tue Aug 08, 2006 5:44 pm ] |
In a 2400 lb drag car my stock engine would pull to about 4400 rpm and quit to much drag and friction. Never had a problem after 5000 rounds. of drag racing. Thanks Ron Parker It Aint Over Until I Win |
| Author: | grthigpen [ Fri Aug 11, 2006 5:10 am ] |
PANIC........clarify??? "a complete waste of time" GRT |
| Author: | Sam Powell [ Fri Aug 11, 2006 5:25 am ] |
It is a complete waste of time to worry about what he means by that. Sam |
| Author: | Bren67Cuda904 [ Fri Aug 11, 2006 5:31 am ] |
It is as Sam said. Panic likes to edit his posts after the fact and than the thread does make much sence. |
| Author: | panic [ Fri Aug 11, 2006 7:52 am ] |
Yes, it's that annoying tendency to remove material that answered the question, only to see... the same question asked again. If you're not going to read it, I won't answer it. |
| Author: | Bren67Cuda904 [ Fri Aug 11, 2006 3:21 pm ] |
Panic You're obviously a bright dude. Some of your information can be over the heads of some, but to others its good information. Editing your text to remove it is a bit selfish to the ones that do understand. No body likes it when you take the ball home (if this were a game). Leave the ball so we can kick it around. |
| Page 1 of 2 | All times are UTC-08:00 |
