It is currently Sun Nov 15, 2026 2:32 am
PostPosted: Wed Aug 09, 2006 10:42 am
Plymouth Voyager 1987 2.2 carb.
Checked EGR and is working fine got the idling engine to shake more when I applied vacuum to EGR valve,
the thermal valve is working as well, just tested. Did the combustion chambers cleaning after the e-test.
Background:
When van is on 2,000rpm test, NOX was failed along with CO. Both are not too far, like 100 points above limits.
I had the timing gun on it when I was testing the EGR vacuum, I get some vacuum at 2,000 rpm but get more stronger if I go above 2,200-2,500rpm.
If yoiu have info on EGR vacuum strength in Hg at 2,000 RPM on a carbed 2.2, please let me know, this is IMPORTANT.
Thanks & Cheers, Wizard
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
