| Questions on holley/weber 5220 carb. https://slantsix.org/forum/viewtopic.php?t=19112 |
| Author: | Wizard [ Wed Aug 09, 2006 7:45 pm ] |
| Post subject: | Questions on holley/weber 5220 carb. |
How much idle mixture screw adjustments affect the idle, off-idle and cruise? when did they shift mostly from idle circuit thru off-idle to cruise? Especially 900 RPM to 3,000 RPM range. Also is there a way to find out if jettings are correct for given vehicle? 1987 Plymouth Voyager 2.2L with 5220 carb. Cheers, Wizard |
