Valve Noise Clicka Clicka Clicka
https://slantsix.org/forum/viewtopic.php?t=19244
Author:  James Webster [ Fri Aug 18, 2006 6:41 pm ]
Post subject:  Valve Noise Clicka Clicka Clicka
Have 1983 Dodge 150. After driving 20 miles what appears to be valve clatter develops. It never happens at low speed around town-only on the highway. Sometimes but not always it will dissapear if its shut off and then restarted. Please help its my baby!!!!
James
Author:  SlantSixDan [ Fri Aug 18, 2006 6:56 pm ]
That '83 engine has hydraulic lifters which are fed their oil via a circuitous and lengthy path. It is probable that a careful engine cleanout will clean things up enough to restore proper oil flow to the lifters.
Author:  Slant Cecil [ Sat Aug 19, 2006 4:29 am ]
Could be that it's an exhaust leak. A leak can sound like a valve or lifter tap.
Use a peice of hose like a stethoscope to locate the tapping noise. A lifter will be more noticeable on the right side of the motor, a few inches below the head. A exh leak can be anywhere around the exh.
