| Front end rebuild https://slantsix.org/forum/viewtopic.php?t=19256 |
| Author: | Holyphil29 [ Sat Aug 19, 2006 2:42 pm ] |
| Post subject: | Front end rebuild |
What is the best front end rebuild kit to go with? PST, perfomance suspension, energy suspension. Does it even matter are they all the same? Thanks, Phil |
| Author: | slantvaliant [ Sat Aug 19, 2006 3:42 pm ] |
The best "kit" is one you put together yourself. I had to do it that way because I was mixing parts from different generations of cars and upgrading some areas. ('64 Valiant, '74 UCA's and disk knuckles, C-body tie rods, etc). The parts came from Rock Auto http://www.rockauto.com/ and Summit http://www.summitracing.com/ primarily. Mancini Racing also has kits, using TRW rubber bushings and parts. http://chucker54.stores.yahoo.net/manciniracing10.html |
| Author: | Charrlie_S [ Sun Aug 20, 2006 4:48 am ] |
I am not real happy with the PST "kit" for a 66 "A" body. I don't like the ball joint boots, and the strut rod bushing need replacing, after only 5 years on a drag car, that sees limited street usage. Also the don't seem very knowedgeable, if you have a question. I have heard good things about ESPO, but have no personal experiance with them. |
