| 7 1/4 leak https://slantsix.org/forum/viewtopic.php?t=19333 |
| Author: | reddart64 [ Thu Aug 24, 2006 11:37 am ] |
| Post subject: | 7 1/4 leak |
Can this rear end leak out of the front of the differential? If so, how hard is it to repair? Thanks, Geoff |
| Author: | Joshie225 [ Thu Aug 24, 2006 11:58 am ] |
Yes, at the pinion seal. Open your factory service manual and you'll see what's required to remove the driveshaft, the pinion nut, yoke, and finally the seal. It will also tell you how to put it all back together properly which is the hard part. |
